Activity Forums Adobe After Effects Text Characters Uniform 3D Rotation
  • Text Characters Uniform 3D Rotation
    Posted by Matei Focseneanu on November 9, 2020 at 5:52 pm
    Let say I have a simple text (first image) :
    It’s all in 3D and I enabled the “Enable Per-Character 3D” of its Text property as my goal would be to have all individual letters to rotate on Y axis.
    The problem is I can’t do otherwise than get each letter which its own angle, due to the kind of view of the camera with a vanishing point (2nd image).
    I’d like to get what’s in the 3rd image, with all letters rotating totally simultaneously with the same angle (with a somehow vanishing point set to infinite).
    Would that still be possible without separating each letter and moving each one separately ? How could I perform this?
    Thanx to everybody that can bring me some help, I’m very beginner on AE.
    Matei Focseneanu replied 5 years, 10 months ago 2 Members · 2 Replies
  • Filip Vandueren
    November 10, 2020 at 4:29 pm
    The easiest way would be to add a camera with the minimum angle of view possible: 0,01°
    That will be very close to an isometric perspective.
    (Note that due to the loss of perspective, this will look exactly the same as scaling the letters from [0,100] to [100,100])
  • Matei Focseneanu
    November 10, 2020 at 9:16 pm
    Thank you Filip, that’s definitely the solution, thanx a lot!
