Activity Forums Adobe After Effects Text changes position when I enable 3D and vice versa when I turn 3D off
  • Text changes position when I enable 3D and vice versa when I turn 3D off
    Posted by Ashley Baron on January 23, 2015 at 7:32 pm
    So I’ve been working in this after effects comp and when I rendered it out, my text had moved out of place in the final rendered video. When I went back in I noticed that when I turned the 3D switch off it moved to the position where it was when it rendered out… I have 10 other comps in this project and none of the other ones are doing this so I don’t know what I’m doing wrong in this one. What other info do you need to help me figure this out?
    Walter Soyka replied 11 years, 7 months ago 2 Members · 1 Reply
  • Walter Soyka
    January 24, 2015 at 1:37 am
    Are you maybe looking at some view other than Active Camera in the viewer for that comp?
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
