Activity Forums Adobe Premiere Pro Text breaks on import from After Effects
  • Text breaks on import from After Effects
    Posted by Rajarshi Basu on November 8, 2007 at 6:32 pm
    I recently did some titles in AFX, and rendered an uncompressed .avi file.
    On importing it to PPro 2, i had to render the file in the timeline. I notice my text quality detoriate, and break up…
    Same settings as AFX comp and PPro project..
    I don’t own a external monitor , so i don;t know if it will look the same way on Tv…
    any suggestions ??
    Raj
    Jon Barrie replied 18 years, 10 months ago 3 Members · 2 Replies
  • Vince Becquiot
    November 8, 2007 at 6:35 pm
    When you render in Premiere, it recompresses to DV (in a DV timeline), you may be seeing compression artifacts.
    Vince
  • Jon Barrie
    November 9, 2007 at 2:41 pm
    It common to have the quality setting in the program monitor to automatic or draft and not know it. Make sure it’s set to High for a proper representation of your final render inside the timeline. If the DV codec render is causing the issue make a new project from the custom tab and make an Windows AVI with no compression in the compressor section of video. It will keep your uncommpressed clip quality. If you are going out to SD tape or TV MPEG (DVD or Broadcast) the Quality won’t show up on a TV Screen working in DV. Comp screens always show nasties that aren’t there on a TV. HD LCD is a different story.
    – Jon Barrie
