Activity › Forums › Adobe Photoshop › Text box (solid color) behind text that resize automatically. Is that possible?
  • Text box (solid color) behind text that resize automatically. Is that possible?
    Posted by Davide Dante on April 1, 2019 at 2:34 pm
    Hi all,
    I’m dealing with a series of banners which feature a text box (solid color with a -stroke- frame) and some text inside.
    As per guidelines I need to have the text box offset of a certain measure from the text on all sides. This is very mechanical, boring and time consuming task that i wonder if i can automate.
    Here’s a rough example of what they need:
    And what of course (don’t) happen when I edit the text.
    I tried to apply effects on the text… like a huge shadow with no fade, but it always follow the line length. Help 🙁
    Kalleheikki Kannisto replied 7 years, 5 months ago 2 Members · 3 Replies
  • Kalleheikki Kannisto
    April 5, 2019 at 2:48 pm
    You can do this with Photoshop actions. Something like the attached.
    You need a file which has a background layer and a text layer and have the text layer active in the layers panel before running the action.
    Adjust action steps to taste.
    13243_textbox.atn.zip
    Senior Graphic Designer
  • Davide Dante
    April 6, 2019 at 10:51 am
    Hi Kalleheikki, thanks for reply, that’s a nice trick ☺ I’m wondering if there is a way to make this box animate live, like while typing in. My guess is that it should happen by applying some effects on the text layer, but that’s just wild speculation…
    April 6, 2019 at 4:01 pm
    In After Effects, yes, in Photoshop, not likely.
