Activity Forums Apple Motion Text box size / amount of text ?
  • Text box size / amount of text ?
    Posted by James Poll on September 6, 2011 at 4:47 pm
    Hello all,
    I’m trying to build a Motion template (Motion 4 with FCP 7) and I’m wondering if there is any way to determine the size of a text box, or the amount of text within a text box.
    Here’s what I’m trying to do:
    I have a big block of red (just a solid with a mask on it), and I need to move it to reveal the text underneath. The problem is that I can’t figure out a way to have it move based on how much text there is (for instance, if I have a long line of text, the solid has to move farther to reveal more, but if I have a short line of text, the solid only needs to move a little way). I’ve been going through the behaviours, but have not been able to find a parameter to link to that will allow me to do this. Are there any Motion experts out there who could give me a couple of ideas?
    Thanks muchly!
    James Poll replied 15 years ago 2 Members · 2 Replies
  • Mark Spencer
    September 6, 2011 at 4:56 pm
    The easiest way to go about this is to use Motion 5 and FCP X because you can build a rig and publish it to FCPX in order to adjust for different text lengths.
    But for Motion 4, you can use a workaround by linking the parameter you want to change (the size of the box) to a dummy text scale parameter which can be adjust in FCP7. This video shows you how:
    https://pixelcorps.cachefly.net/mbks_078_540p_h264.mov
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • James Poll
    September 6, 2011 at 5:19 pm
    Wow, thanks Mark for the quick response!
    That’s exactly what I needed. I had been playing around with the Link behaviour, but couldn’t find anything to link to. The idea of a dummy text scale is so clever, and yet so simple, that I’m totally face-palming myself for not figuring this out before.
    Think I’m going to go get that Motion Cheats book!
    Thanks again… very much appreciated!
