Activity › Forums › Adobe After Effects › Text box in one layer
  • Text box in one layer
    Posted by Davide Dante on November 27, 2019 at 12:42 pm
    Hi guys,
    I am trying to achieve a dynamic text box within the text layer.
    I’m aware of the technique of assigning a script to a box layer, so that if resize and position behind the text box:
    s=thisComp.layer(“Text”);
    w=s.sourceRectAtTime().width;
    h=s.sourceRectAtTime().height;
    [w,h]
    but I don’t want to have a separate layer for the box! This because I need to use this massively for my projects and when i paste the text and box i have to edit the script manually to match the name of the text layer (so “Text” becomes “Text 2”, “Text 3” and so forth)
    I found a partial solution to my problem, which is inverting the alpha. I use the drop shadow to create a controllable offset around the text, so that the box is not too tight around the text:
    The only issue here is that the text is transparent :-\ I can’t find a way to assign a color to it. Any clues?
    Tomas Bumbulevičius replied 6 years, 10 months ago 3 Members · 4 Replies
