Activity › Forums › Adobe After Effects › Text bounce scale animation by characters
  • John Cuevas
    August 12, 2014 at 3:44 pm
    You might want to try the free preset Amortype 2.0
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • John Cuevas
    August 12, 2014 at 4:23 pm
    This might be easier—Here I just made 2 text animators, one scales up the text past what you want, the other brings it back down a bit. All you need to do is copy the first offset parameter into the second offset parameter and move it a couple of frames back.
    7861_textovershoot.aep.zip
    Thinkck.com
  • Orkhan Huseynov
    August 12, 2014 at 6:43 pm
    You wanna say that to control the frame of start and stop, I need just set offset parameter in seconds?
  • Orkhan Huseynov
    August 12, 2014 at 7:56 pm
    Armotype is niceç but i can’t set the start time and animate out. How to set start time, not from composition start?
  • John Cuevas
    August 12, 2014 at 8:49 pm
    Are you using Amortype or the little project I made?
    Thinkck.com
  • Orkhan Huseynov
    August 12, 2014 at 10:07 pm
    Thank you for both solutions. I am using amortype, it’s has soft bounce and more parameters. I couldn’t set the inner and outer, but then I found it. Just crop text laver In timeline. Thanks, really helped.
