Activity Forums Adobe Encore DVD Text blurs in opening animation .. why?
  • Text blurs in opening animation .. why?
    Posted by Mike Wheeler on August 23, 2007 at 11:00 am
    Hello,
    I am relatively inexperienced using Encore 2.0.
    I have created an animation where curtains open revealing the menu buttons below, the animation then stops at a static image with the menu buttons on it. I have created the inital animation using after effects, then exported the final frame of that animation as a photoshop layered document and imported that into Encore to use as the menu.
    The problem I am having is that when this inital animation plays, everything blurs for a second as the animation turns into the photoshop menu.
    Does anyone have any idea what is causing this, or have any suggestions as how to create an animation that will stop and be the menu?
    A BIG thanks in advance!
    Mike Wheeler replied 19 years ago 1 Member · 0 Replies
  • 0 Replies
