Activity › Forums › Adobe After Effects Expressions › Text Blinking On Expression
Posted by Mike Moon on March 28, 2014 at 10:55 pmHello All,
I’m not very good with expressions and I wanted to know if there were any expressions for text that would make them randomly blink on. Kind of like how a flourescent light would when you first turn it on but randomly with random text?
Mike Moon replied 9 years, 8 months ago 3 Members · 7 Replies -
George Goodman
March 31, 2014 at 2:06 pmIn order to change how frequently it shuts on and off, just change the first wiggle value. The bigger that number, the faster it should flicker.
Set your opacity to 50 then put this expression in it:on=100;
off=0;
x=wiggle(10,50)
if (x>50) on else off“|_ (°_0) _|”
Sincerely,
George
Mike Moon
April 2, 2014 at 11:11 pmHmm, my question was more in regard to each individual letters blinking on and off randomly till they are all lit. I was wondering if there was an AE text animation preset that does that? Thanks.
George Goodman
April 3, 2014 at 1:50 pmOk, gotchya. There is probably a better way, but this will work.
-Take your text layer, right click, and convert to shapes.
-Open up the shape layer and go to the transform>opacity section of each letter, set it to 50, and enter the expression below. (not the one where I explain things, obviously)Here is how to alter it for different results
on=100;
off=0;
x=wiggle(10,50); – Change the 10 to a larger number for faster blinking, or lower for slower
r=random(9);
if (time<5+(r*.1)){ – Change the 5 to the second you want the effect to stop, in this case the effect ends 5 seconds into the timeline. The (r*.1) is an additional parameter to make them stop at different points. So this equation is saying stop at 5 seconds plus a random number (1-9) *.1 -So each one will stop at 5.3 or 5.7 or 5.2 – whatever it generates. If you would like there to be a longer gap between each one stopping, simple make the .1 a larger number. The larger you go, the longer it can wait to stop the effect
if (x>50) on else off}
else onThe reason this approach sucks is because you have to manually enter it for each letter and if you want to change it, you have to change each expression, rather than just one. But it will do the trick. And if you do need to alter them all, just press “e” with the layer selected and it will bring up all of the expressions.
on=100;
off=0;
x=wiggle(10,50);
r=random(9);
if (time<5+(r*.1)){
else on“|_ (°_0) _|”
Sincerely,
George
Mike Moon
January 20, 2017 at 5:41 pmWow I must of been in a time crunch when I asked for your help and prob just jimmy rigged the effect the long way. Coincidentally I’m faced with this problem again and found my original post. I tried your script and it seems to give me an error. By the way I wanted the individual letters to blink and then stay on. So they go from 0 opacity and blink to 100 opacity. Kind of like a florescent bulb.
After Effects warning: an expression was disabled as a result of an error.
Error at line 5 in property ‘Opacity’ of layer 1
Can anyone help with this? Thanks
George Goodman
January 20, 2017 at 6:45 pmShould be that instead. It looks like the formatting of the expression added an &Lt for some reason. I didn’t test this, I’m just looking at the inconsistency between my explanation of the code and the actual code you probably copy and pasted. That line definitely doesn’t make any sense as is though.
if (time<5+(r*.1))“|_ (°_0) _|”
Sincerely,
George
http://www.vimeo.com/georgegoodman
http://www.linkedin.com/in/georgefranklingoodman -
Dan Ebberts
January 20, 2017 at 6:50 pmIf you post code, it’s best not to preview it first, or your < characters will get mangled.
Dan
Mike Moon
January 20, 2017 at 8:05 pmCall me crazy but the new code you posted looks the same as the old one.
original post:
on=100;
off=0;
x=wiggle(10,50);
r=random(9);
if (time<5+(r*.1)){
else onnew code:
if (time<5+(r*.1))
