Activity › Forums › Adobe After Effects › Text appearing from behind object
Posted by Gavin Williams on January 3, 2014 at 10:42 amHi
Hoping someone can help on this – I want text to move from behind a single vertical white line like it is appearing from behind?
Gavin
John Cuevas replied 12 years, 8 months ago 3 Members · 10 Replies -
Gavin Williams
January 3, 2014 at 12:14 pmSo how do I stop the mask being connected to the text – can’t seem to seperate the two. Sorry for the basic Qs!
Marc Lucas
January 3, 2014 at 12:16 pmIf you animate the Mask Path to reveal your text then just animate the Mask path to somewhere where its not going to affect the text afterwards.
John Cuevas
January 3, 2014 at 2:43 pmGavin, you might also want to experiment with the linear wipe effect. You can apply that, set where you want the text to appear from by adjusting the transition completion, and then just move the text position properties.
Also, here is a thread with a similar question that tackles the problem, and in there I included a sample project that should help you with the technique.
https://forums.creativecow.net/thread/2/1038781#1038792
Johnny Cuevas, Editor
Thinkck.com“I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
—THOMAS EDISON on inventing the light bulb. -
Gavin Williams
January 3, 2014 at 6:14 pmThanks so much – got it working on the linear wipe option. I still don’t get why the masks I assign to a text layer are tied to the text so I can’t move the mask without the text going with it? Why can’t the mask stay in one position and the text move from behind it into view? Can I unconnect them in any way?
Gavin Williams
January 3, 2014 at 6:20 pmAnd will the text move and the mask stay put if I change the text path?
John Cuevas
January 3, 2014 at 7:41 pmIF you animate the mask path only, the text will not move, just the mask around it.
John Cuevas
January 11, 2014 at 2:24 amGlad we were able to help you out.
