Activity › Forums › Adobe After Effects › Text appear effect
Text appear effect
Posted by Kalyan Tagore on November 2, 2012 at 6:13 amHi people I am an ‘intermidiate’ user of after effects. Can anyone plz guide me how to create the effect (the words appearing effect) from the below given video link?
https://www.tavo.es/v2/view.php?vid=../motion/musicone/presentation.mov&w=480&h=380&title=Music%20One%20Classic
Brian Charles replied 13 years, 10 months ago 5 Members · 6 Replies -
Tudor “ted” jelescu
November 2, 2012 at 6:37 amThe text itself is revealed by a animated mask with a feathered edge. The animated organic shapes on top can be created by animating either Shape Layers or with a technique similar to the one in this tutorial:
https://layersmagazine.com/animated-swirls-in-adobe-after-effects.htmlTudor “Ted” Jelescu
Senior VFX Artist -
Kalyan Tagore
November 2, 2012 at 6:59 amHI TED, thanks for the reply. My question is actually about how to create the cool animation of the shapes?…It was very nicely done.
But the link u gave me is more like creating ‘Evolution’ kinda effect!
I need to know how can I create that shape animation.
Tudor “ted” jelescu
November 2, 2012 at 7:41 amIt’s basically the same technique- you need to create the shapes by manipulating the stroke in Illustrator. Once you get a few shapes down you can animate them and pre-render with alpha. You can then change the color, size and timing, comp several shapes on top of each other and create the animation that reveals the text.
Tudor “Ted” Jelescu
Senior VFX Artist -
Vishesh Arora
November 2, 2012 at 10:03 amKalyan
You can create the shapes in AE by using Pen Tool.
Here is an Example which may help:
https://www.youtube.com/watch?v=j7JXhnQ_RjU
After animating then shapes, you can render them as Ted suggested you and then use it in any way you want.
Vishesh Arora
3D and Motion Graphics Artist
Films RajendraBlog:
https://digieffects.wordpress.comDemo Reel(3D):
https://www.youtube.com/watch?v=lHPgIJU_BR8Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Joseph W. bourke
November 2, 2012 at 1:24 pmActually it looks to me like a Trapcode 3D Stroke animation with the stroke settings not the normal “swash”, and possibly the thickness setting animated.
Joe Bourke
Owner/Creative Director
Bourke Media
http://www.bourkemedia.com -
Brian Charles
November 3, 2012 at 3:16 pmIn the absence of 3D Stroke – an excellent and indispensable product – you may be able achieve something similar with CC. Mr. Mercury.
Here’s as sample. You can tweak the settings to suit your needs. The Base Comp is set to 60 fps for smoother motion then Time Remapped in the final. Copies of the Base are scaled, rotated and re-positioned to suit.
