Activity Forums Adobe After Effects Text Animators and echo
  • Text Animators and echo
    Posted by Kalin Cahal on February 16, 2006 at 4:04 am
    Hello all,
    I’m trying to do the following effect with a text layer:
    -per word horizontal animate-in(as in translates in)
    -each words translating in has clones around, that are faded(some sort of echo, not motion blur)
    -when the word is close to it’s final position all clones converge back to the position of the normal word so that it appears as normal text in the end
    How could this be done with a minimum of layer, and by keeping it some sort of “template”(i have quite some text to do with that effect)
    Thanks for any hints,
    Kali Cahal
    Note: i have successfully done the effect by using the following methods:
    -2 layers using the echo effect
    -1 layer per word with the echo effect
    Kalin Cahal replied 20 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
