Activity Forums Adobe After Effects Expressions Text animator offset expression to react to source text
  • Text animator offset expression to react to source text
    Posted by Otávio Nascimento on October 16, 2022 at 8:07 pm
    I need a expression to make 2 animators offsets to always adjust to the selected number of characters I set in the offset. So when I type more characters the range selector only affects the number of characters I set previously. I have 2 animators with range selector (square). One set to 80 and other to -80.
    Filip Vandueren replied 3 years, 11 months ago 2 Members · 2 Replies
  • Otávio Nascimento
    October 16, 2022 at 9:07 pm
    When I animate the source text with a slider, the offset still selecting the same number of characters.
  • Filip Vandueren
    October 18, 2022 at 7:01 am
    Make sure Range is index-based:
    Animator > Range > Advanced Settings > Based on: Index
    For me, the numbers do not change when I edit the text?
    But when the animator is percentage based (the default), the 80% of the characters is indeed depnding on how much text you have typed.
