Activity › Forums › Adobe After Effects Expressions › text animation?
text animation?
Posted by Hamid Rohi-bilverdy on January 22, 2010 at 3:17 pmhi
I know how to set my text to animate, but i cant figure out how to get a number value from 0 to 100? How do i use wiggle to get this done?Hamid Rohi-bilverdy replied 16 years, 7 months ago 2 Members · 7 Replies -
Dan Ebberts
January 22, 2010 at 7:03 pmYou could “borrow” one of the other properties, like rotation, with a source text expression like this:
w = 50 + (transform.rotation.wiggle(.1,50) – transform.rotation);
w.toFixed(0)Dan
Hamid Rohi-bilverdy
January 23, 2010 at 5:42 pmOk sorry if I wasnt specific enough. first off all.i am new to expressions, so can you advice in simpel steps. Second I just want a text animation value with the number 0 going to 100 and then stops at 100.
What is the easiest way for this?
regards Hamid
Dan Ebberts
January 23, 2010 at 6:04 pmThis expression will count from 0 to 100 over a 4-second interval.
startT = 0;
endT = 4;
beginVal = 0;
endVal = 100;
t = linear(time,startT,endT,beginVal,endVal);
t.toFixed(0)Steps:
1. Copy the expression
2. Alt+click the Source Text stopwatch
3. Paste the expressionDan
Hamid Rohi-bilverdy
January 24, 2010 at 8:57 amthanks so much Dan. I will try this when i get home today. I think it is just what i need. So in 4 seconds it goes from 0 to 100 and stays there, am i right?
One last question if you be so kind, how do i get a blinking effect. I mean e.g the word scanning should blink/apear and disapear. Like a robot scanning for an object. I hope you get the idea.
Regards Hamid -
Dan Ebberts
January 24, 2010 at 8:32 pmThere are many ways to do this. One would be to keyframe one on-off cycle of the layer’s opacity and add this expression to the opacity property:
loopOut()
Dan
Hamid Rohi-bilverdy
January 25, 2010 at 9:03 pmok. You mean that i keyframe an opacity value of 100 and then a couple frames later i keyframe to 0 and then add the script?
