Activity Forums Adobe After Effects Text Animation Question
  • Text Animation Question
    Posted by Stefan Evans on September 12, 2014 at 3:40 pm
    Probably a fairly easy one but my google searches didn’t help me.
    I’m trying to mimick a technique I’ve seen around the place, which is like a typewriter transition except the letters fade in a random order. Any quick tips on how to do this?
    Here’s an example at 12 seconds: https://vimeo.com/102778758
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Derek Boettcher replied 11 years, 11 months ago 2 Members · 1 Reply
  • Derek Boettcher
    September 12, 2014 at 10:27 pm
    You can find this in the text animation section. Click the down arrow next to your text in the time line. On the right side you will see Animate: > go ahead and hit that drop down. Check opacity. Key frame your start 0%-100%, and then turn the randomizer on. I’m doing that from memory, so there may be a little give and take. But that should at least get you in the right direction. Try playing with the opacity level too.
    Best,
    Derek Boettcher
    Creative Management
    BTH Media Group
    https://bthmedia.com
