Activity Forums Adobe After Effects Text animation question
  • Text animation question
    Posted by Anthony Marzilli on February 19, 2013 at 3:22 pm
    I love this guys work. Frasier Davidson. You can get what I am trying to achieve in the first 2 seconds of the video…. it does continue throughout the video if you want to watch.
    His text rotates from the top down and swings a bit. I cant match how it looks!
    What I have tried so far is enabling per 3d…. add a rotation animator… move the anchor point to the top… but I cant get the swing at the bottom… or have it fade in nicely the way he does. I can see to add turbulent displacement on the text to give it the jittery look.
    I would appreciate any tips. I feel it has to do with two animators on the text but am having trouble figuring it out on my own. Im glad I have you guys here to fall back on. Thank you.
    https://vimeo.com/35003246
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Stef Prein replied 12 years, 9 months ago 3 Members · 3 Replies
  • Ridley Walker
    February 19, 2013 at 4:27 pm
    You might try a free preset from Mattrunks called AmorType.
    https://www.mattrunks.com/en/tutorials/after-effects/amortype
    Modify the first animator to 90 degrees X rotation and adjust the anchor point grouping alignment to -100%.
    It looks like the Fraser Davidson example is not fading in but responding to a light in the scene.
  • Anthony Marzilli
    February 19, 2013 at 4:52 pm
    Ridley…. that is perfect. I fudged with the parameters a bit and its exactly what I was looking for. Added an opacity parameter and it works great.
    Dave. You were spot on. Its expressions….. man those guys are smart who write those things.
  • Stef Prein
    November 24, 2013 at 9:54 am
    “Modify the first animator to 90 degrees X rotation and adjust the anchor point grouping alignment to -100%.”
    This is exactly the answer I was looking for 🙂 Thanks!
    Stef Prein
    director/motion designer at StudioFets.
    Utrecht, The Netherlands
    https://www.studiofets.com
