Activity › Forums › Adobe After Effects › Text Animation Presets
  • Text Animation Presets
    Posted by Ted Cacciola on March 25, 2010 at 12:03 pm
    So I open Adobe After Effects CS3 in Windows 7. I import a video file, I add a new solid layer. I add basic text to the solid layer. And drag and drop an animation preset, lets say 360 loop under paths and all that shows is a picture of the path of the render and nothing actually renders, as in the text effect does not happen and in this case a picutre of a 360 loop shows up and nothing renders. What am I doing wrong. Sorry I’m a after effects newb who just switched from motion. Thanks. Ted
    Todd Kopriva replied 16 years, 6 months ago 2 Members · 1 Reply
  • Todd Kopriva
    March 25, 2010 at 4:17 pm
    You mean that you added the Basic Text effect? Don’t do that. That effect is in the Obsolete category for a reason. Instead, use the Type tools to create text in a text layer. Then, you can add text animation presets to the text layer.
    I recommend that you start here to learn about text animation.
    I also strongly recommend that you work your way through the resources here if you’re just getting started with After Effects.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
