Activity › Forums › Maxon Cinema 4D › Text animated around Object
  • Adam Trachtenberg
    August 2, 2010 at 10:14 pm
    Depends on the exact look you’re after. If you want the letters to actually deform, I would use a spline mask to bend them along a helix spline. If you just want to rotate the letters you could use a mograph text object and control rotation with a step effector.
