Activity Forums Adobe After Effects Expressions Text and Markers expression issue
  • Text and Markers expression issue
    Posted by Levi George on January 9, 2014 at 6:11 am
    Hi!
    So I’m working on an animatic template where a text asset can read into the markers on a comp and display the shot number. I’m using Markers at the start and end of each shot, where each cut is. It means I can drag these markers around and the label will update automatically. I’ll eventually expand this for frames and shot length etc.
    I put some code in a text object hoping the text would display the correct shot number.
    but as soon as it moves onto the second Marker it just reads
    [object layer]
    My code is below.
    Thanks for your help in advance.
    for (
    n=1 ;
    time>=thisComp.marker.key(n).time && time<thisComp.marker.key(n+1).time ;
    n++)
    {value = n} ;
    Levi George replied 12 years, 7 months ago 2 Members · 2 Replies
  • Dan Ebberts
    January 9, 2014 at 6:23 am
    It should be close to this:
    m = thisComp.marker;
    n = 0;
    if (m.numKeys > 0){
    n = m.nearestKey(time).index;
    if (m.key(n).time > time) n--;
    n
    Dan
  • Levi George
    January 12, 2014 at 3:06 am
    It was exactly that! Thank you very much!
