Activity Forums Adobe Premiere Pro Text and Graphics Animation in Premiere
  • Text and Graphics Animation in Premiere
    Posted by Mike Prosser on July 27, 2010 at 12:55 am
    I am on CS4.
    1) Animating titles and .jpegs looks interlaced and jagged in Premiere. I don’t seem to have these issues in After Effects. Is there a way to get rid of this INSIDE Premiere?
    2) When I animate moving text or graphics I get a shift at the beginning of the move instead of a clean straight line from point to point. I have tried duplicating the points and alt-clicking points. nothing seems to work. Any insights?
    Thanks.
    – Mike Prosser
    Mike Prosser replied 16 years, 1 month ago 2 Members · 2 Replies
  • Rex Summerfield
    August 1, 2010 at 3:01 am
    Mike a few things to try would be to make sure the graphics are the same size as the project so you aren’t resizing them dramatically on the timeline. It may also simply be your preview setting and not the actual graphic at all. Make sure the clip is rendered on the timeline and the preview is set to highest quality in the drop down menu available in the upper right corner of the preview pane.
    On the weird tracking between key frames you can right click on the key frames and make sure the Temporal and Spatial Interpolation is set to linear and not Bezier. If that doesn’t solve it the only thing to do it delete the existing key frames and reset the movement with new ones. Not copy and paste. For some reason Premier can get glitches with the linear path between key frames.
  • Mike Prosser
    August 2, 2010 at 6:30 pm
    Thanks a lot! I’ll give it a shot!
    – Mike Prosser
