Activity › Forums › Apple Final Cut Pro Legacy › Text and Dissolves affecting Color and Gamma
  • Text and Dissolves affecting Color and Gamma
    Posted by Tangier Clarke on November 2, 2009 at 11:23 pm
    Folks, I don’t know why this is happening nor how to correct it: I am adding individual credits using the FCP text generator, fading them up, fading them out.
    Whenever a cross dissolve is used on the text elements, the clips below (which have different color color correcting filters seem to become negated. I’ve tried adjusting my video processing settings with no success. Here’s my setup right now:
    Sequence = XDCAM EX 1080p24
    Render settings = Render in 8-bit YUV
    Process Maximum White as White
    Color correcting filters were already rendered before starting to apply credits above.
    Michael Gissing replied 16 years, 11 months ago 2 Members · 3 Replies
  • Michael Gissing
    November 2, 2009 at 11:35 pm
    So credits over picture with a dissolve in between the text elements. Have you fully rendered and this is happening?
  • Tangier Clarke
    November 2, 2009 at 11:39 pm
    Yes, I’ve fully rendered them.
    Tangier
  • Michael Gissing
    November 3, 2009 at 1:36 am
    One place to start is instead of using a dissolve to fade in and out, try using keyframes on the text elements and doing an opacity ramp to zero or up from zero.
    It may be that something in the dissolve type might be altering the color & gamma of the underlying clip. Are you using cross dissolve or something like dip to color or..???
