Activity Forums Adobe After Effects Text Alignment In Element 3D
  • Text Alignment In Element 3D
    Posted by John Davies on March 25, 2014 at 6:11 pm
    I am building a 30 minute countdown timer for an event. Using Dan’s brilliant expression, I have my text counting down perfectly.
    I’ve then used Element 3D to style the text and to allow for some random 3D movement on the camera. The problem lies in the alignment of the text though as it counts down. The different size and shapes of each number as it changes causes the alignment of the text to jump slightly, as it is all re-positioned to accommodate the new number.
    Does anyone know of any workarounds or if there’s any alignment settings that Element would read?
    The text layer that Element is reading from doesn’t jump about in the same way, and all alignment/paragraph settings applied make no changes in the 3D layer.
    Any help appreciated!
    Joseph W. bourke replied 12 years, 6 months ago 3 Members · 2 Replies
  • Cassius Marques
    March 25, 2014 at 8:55 pm
    Have you tried turning off auto scale?
    Or maybe you can add some geometry that will keep your bounding box consistent as the inner numbers change. That you can after mask it out, or set it invisible with materials, idk. Never actually tried.
  • Joseph W. bourke
    March 25, 2014 at 9:38 pm
    It’s also important to use a monospaced font, that is, a font which has a fixed width – not using one will often cause this problem:
    https://en.wikipedia.org/wiki/Samples_of_monospaced_typefaces
    Joe Bourke
    Owner/Creative Director
    Bourke Media
    http://www.bourkemedia.com
