  • Posted by Tony Luke on June 20, 2007 at 8:04 pm
    Hey I’m trying to use a tutorial on reflections but it requires creating text. I have AE 5.5 and can’t find a simple text tool – i can’t add a text as an effect, it has to be solely text. The tutorial is using 7.0 though – is there something different between the two versions with text? Thanks a lot!
    Mike Clasby replied 19 years, 3 months ago 3 Members · 2 Replies
  • Kevin Camp
    June 20, 2007 at 8:33 pm
    it has been a while since i used 5.5, but i think you will need to create text with the basic text effect in the effects window (or menu). i think it was 6 or 6.5 that introduced a text tool similar to photoshop/illustrator.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
  • Mike Clasby
    June 20, 2007 at 9:58 pm
    Yep, not text Toll back then, try Effect>Text then Basic Text, Numbers or Path Text. They’re not bad, really.
