  • Posted by Sandra Pine on December 3, 2012 at 4:12 am
    Hi
    I’m new to After Effects … just started a few days ago
    I am editing a template … It is a video clip
    I added some text but when I preview it the texts won’t stay where it was placed … it follows throughout the video
    Not sure what I’m doing wrong … but i’m sure there is a simple answer
    Thank you in advance
    S
    Sandra Pine replied 13 years, 9 months ago 2 Members · 3 Replies
  • Sean Simon
    December 3, 2012 at 4:38 am
    Check the text layer to see if there are any keyframes.
    https://lozemo.blogspot.com.au/
  • Sandra Pine
    December 3, 2012 at 4:42 am
    Thank you for responding
    Figured it out in the mean time
    S
  • Sandra Pine
    December 3, 2012 at 4:50 am
    What I had to do was set it as a 3D object to stop it from following the camera movement that was already programed in the template. When I did that it would move the layer in the middle of the canvas and make it very very small therefore I manually dragged it and scaled it. Now everything works fine.
    In order for that to work I erased my true comp duplicator layers and restarted that section. I had no idea where the layers where moving to before I restarted everything when I hit 3D because I could not see them.
    I realize this might not be the most efficient way of doing it but hey I’m a noob and it works YAY!
    Thank you for the fast reply
    S
