Testing:Accusonus Era 5 Bundle vs Izotope RX 8 Audio Repair Plugin Premiere 14.4
I have briefly tested Accusonus Era 5 Bundle (ERA_Bundle_v5.0.00-WIN) vs Izotope RX 8 Audio Repair Advanced Plugins – Premiere Pro 14.4 2020
Era 5 has got very impressive interface and used few functions and happy with it .(I was also testing/trying the RX8 plugins on some audio clips until decided to (pre) render the timeline (ProRes) .
Premiere crashed at all my attempts.
Assuming the problem was with Premiere, I cleaned appdata & audio video previews, and reset everything with the premiere.
– unable to start the existing project – premiere crashed
I then the disabled the RX 8 plugin in the premiere
– unable to start the existing project – premiere crashedI disabled Era 5 plugin in the premiere
successfully restarted the premiere projectenabled RX 8 plugin in the premiere
successfully restarted the premiere projectI like the Era 5 Audio Clean up assistant interface very much where Izotope RX plugin doesn’t seem to have one
unless you want to start the standalone application where it exists and tests the audio and tells you what portions need to be fixed – very impressive.if it does offer the same assistant in the plugin version that would be comparatively better
According to some Era 5 review many problems not being fixed
– The Master bypass switch of Audio Clean-Up Assistant doesn’t compensate for the latency automatically. Workaround: Set a fixed latency value if your host supports it.
– The step of the Processing Response parameter of Reverb Remover Pro is reported to the host automation as an integer instead of a decimal.
– Audio issue when loading Voice Deepener as a multi-mono plug-in on a stereo track in Pro Tools. Prefer multichannel plug-in instead.
– [Noise Remover Pro/Reverb Remover Pro] Linking a band affects the available processing range of the main knob until you unlink the band. Might cause problem with the automation.
– [Noise Remover Pro/Reverb Remover Pro/De-Esser Pro] The preset menu isn’t centered compared to the preset button.
– Buggy behavior with some editable labels of De-Esser Pro controls.
– There’s an overlap between the screen overlay of Licenser and Voice autoEQ. Simply sign-in and everything will return to normal.
– [GarageBand/Audio Clean-Up Assistant] A system overload popup may appear when changing presets or when loading an ERA tool into a slot.
[Premiere Pro 2020 / AudioUnit only] The output of Voice Leveler is not correct. Use the VST format instead.
And perhaps many more including the one I have : -premiere crash
I would like very much to use both,
– if Era 5 bugs are fixed
-if RX8 assistant available in the plugin versionWhat is your experience?
