Test to Confirm bug in VP16 Build 424
Graham Bernard replied 7 years, 3 months ago 4 Members · 14 Replies
Bruce Brent
May 24, 2019 at 3:55 pmPaul, re-set Vegas Pro to factory settings.
Close the program (Movie Studio/Vegas/DVD Architect,etc…).
Hold down the CTRL + SHIFT keys at the same time AND ALSO AT THE SAME TIME double click program icon on Desktop to Boot program.
Window will pop up.
Select Delete all Cached Application Data and then press Yes.
This will restore program to Factory Default Settings.Let us know if this re-set fixes the problem.
Paul Berk
May 24, 2019 at 8:54 pmThanks Bruce .. I’ll try to do a reset as you suggest later today or tomorrow .. as time permits.
George Dean
May 25, 2019 at 1:04 amI doubt this is going to help, it didn’t help for me. My cached application data is regularly deleted.
Best Regards……George
Graham Bernard
May 25, 2019 at 5:16 amHah! Reproduced:
[Paul Berk] 4. Move the timeline cursor exactly one frame (left or right) and split the event again at that point.
5. This leaves a one frame event on the timeline.
“Wishing to be exact, I concentrated on selecting EXACTLY ONE Frame, I did this by using the KeyBoard Command to select ONE Frame and NOT moving the Cursor Manually, and then Splitting the END of the Selection – this is EXACTLY ONE Frame. This way no reproduction. So, inadvertently, I’ve flagged-up convergence.
Now this IS interesting. It would appear that KB Strokes work. Could THIS mean that accuracy is down to using KB Strokes and that Manual Manipulation can’t be relied upon?
* Grazie
Cameras: Canon XF300 + PowerShot SX60HS Bridge
