Activity Forums AJA Video Systems Test image corruption
  • Test image corruption
    Posted by Ajay Bhadresa on October 11, 2007 at 2:30 pm
    Hi there,
    I’m using a Kona LS card and so far so good. However, when I select an image to use instead of the standard test one initially it displays fine. However, when I launch an app like FCP or AE and then exit the display image goes all green. Any ideas why this might be?
    Jeremy Garchow replied 18 years, 11 months ago 2 Members · 4 Replies
  • Jeremy Garchow
    October 11, 2007 at 3:25 pm
    FCP and AE have ultimate control over the Kona card, when you launch those programs and they are active they now have control.
    Jeremy
  • Ajay Bhadresa
    October 11, 2007 at 3:30 pm
    Hi Jeremy,
    Thanks for your response, maybe I was being a bit unclear in my original post. My test file dispays fine when I first select it. After having worked in AE or FCP (or whatever other util) when I return to my desktop (all Kona apps closed) that’s when the corruption in the test image occurs.
  • Jeremy Garchow
    October 11, 2007 at 3:45 pm
    Set the default Kona output as your test image in the Control tab of the Kona control panel.
    Keep the KonaCP open at all times.
    Jeremy
  • Jeremy Garchow
    October 11, 2007 at 3:50 pm
    Sorry, I totally get what you are saying now.
    This appears to be a bug. I would notify support@aja.com and see what they say.
    It has to do with the frame buffer not returning to RGB after switching from FCP and YUV.
    Jeremy
