Activity Forums Adobe Premiere Pro Test Drive Premier Pro on Win 7: Stops working during Startup
  • Test Drive Premier Pro on Win 7: Stops working during Startup
    Posted by Mike Olson on July 22, 2012 at 7:05 pm
    I’m test driving Premier Pro CS 6 demo. It installed properly as far as I can tell, but each time I try to run it, it gets to the “Welcome to: screen and Windows announces it has stopped responding.
    Does it leave a log somewhere that might explain the situation?
    If not, can someone suggest a solution?
    The machine is not state-of-the art, but it runs Vegas Pro OK without GPU acceleration. (Win 7 64 bit, 8 Gig memory, Core 2 Q6600 CPU, NVIDIA Geforce 9500 GT).
    Thanks in advance.
    Mike Olson replied 14 years, 1 month ago 1 Member · 1 Reply
  • Mike Olson
    July 22, 2012 at 8:27 pm
    I found the problem; a old post mentioned that CS4 was intolerant of Kontakt 3 and failed when it scanned it. Nothing has changed; CS6 fails when it touches Kontakt 5. Hiding the VSTplugin folder solved my problem.
