Activity › Forums › Apple Final Cut Pro Legacy › terrible quality mporting mini dv footage onto FCP
Posted by Aubrey Fields on October 5, 2010 at 11:54 amHello,
I am trying to import mini dv footage (from a tape that was shot with a different video camera) from my Sony Z1u into FCP. I have tried every setting on both my camera and FCP, but when I export to QuickTime (as current settings) the .mov file I get looks terrible — like its really low res.
Can anyone help me please?Thanks,
Aubrey.Aubrey Fields replied 15 years, 11 months ago 4 Members · 7 Replies -
Rob Grauert
October 5, 2010 at 3:54 pmSD footage always looks like crap when viewing a Quicktime on a computer screen. This is because computer screens have square pixels and SD video footage uses non-square pixels.
Review your footage on a broadcast monitor or TV
Rob Grauert, Jr.
http://www.robgrauert.com
command-r.tumblr.com -
Walter Soyka
October 5, 2010 at 5:18 pm[Aubrey Fields] “I have tried every setting on both my camera and FCP, but when I export to QuickTime (as current settings) the .mov file I get looks terrible — like its really low res.”
By default, Quicktime plays back DV-encoded files at reduced quality. This might have made sense in 1999, but with today’s computers, realtime playback of DV material is not a problem.
In QuickTime Player > Preferences > General, make sure Use high-quality video settings when available is checked.
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
Bret Williams
October 5, 2010 at 5:47 pmMy DV work doesn’t have artifacts. What are you doing to your footage? Most likely he simply doesn’t have the high quality checkbox checked in QT. The file should look perfectly fine on a NTSC monitor.
Bret Williams
October 5, 2010 at 5:51 pmThe footage might look distorted, but should still be sharp as a tack at 100% with the high quality check box on. Non-square pixels isn’t the culprit. If that were the case DVCPro would look like crap on a computer. Can’t get much more non-square than that.
Walter Soyka
October 5, 2010 at 5:56 pmAll DV has artifacts. DV is heavily compressed (5:1) and uses 4:1:1 chroma sub-sampling (4:2:0 for PAL). It’s particularly tough on graphics, because fine edge detail causes ringing or mosquito noise with DCT-based compression.
When you’re cutting untouched camera originals, it doesn’t make any difference, but as soon as you add graphics or effects, you’ll notice a difference rendering to ProRes or uncompressed rather than DV. You’re better off using a mastering codec even if you’re going to the web, because the added DV artifacts decrease compression efficiency down the line.
Walter Soyka
Rob Grauert
October 5, 2010 at 6:09 pmoops, sorry. The pixel thing is just what I was told in college.
Rob Grauert, Jr.
Aubrey Fields
October 9, 2010 at 12:05 amThank you Dave, Bret, Walter and Rob, your help was very much appreciated.
My footage looks a whole lot better now! Firstly, I didn’t have the QuickTime ‘use high quality video setting when available’ box checked… secondly, when I put the footage on a DVD a watched it on the TV it looked fine, and thirdly, I will definitely have a play around with the ProRes 422!
Thank again!
Aubrey.
