Activity Forums Adobe After Effects Terrible Green Screen Results
  • Terrible Green Screen Results
    Posted by Simon Roughan on March 31, 2014 at 1:53 pm
    Hi everyone,
    I have some footage here that was shot on an Panasonic AG-HPX600, Full HD with AVC Intra-100 codec.
    It was shot in our newsroom studio against a green screen.
    For the life of me, I can’t get a clean key with Keylight. The original footage itself is somehow very noisy, especially on the suit jacket and hair. I can’t understand why. The lighting is good (at least I think so. It was set up by someone who should know.
    Here is a link to download 10 seconds of the material. It is rendered out from AE with Quicktime YUV 8 bit 4:2:2 codec.
    https://video.rnf.de/EXAMPLE.zip
    If anyone has a bit of time to spare, please look at the material and tell me what I’m doing wrong. And if you can get a clean key, please tell me how you did it.
    Thanks heaps,
    mfg
    Simon
    p.s. After Effects CC, up to date.
    Todd Kopriva replied 12 years, 5 months ago 4 Members · 6 Replies
  • Simon Roughan
    April 1, 2014 at 5:11 am
    Hi Dave,
    and thanks as usual for your time and input.
    I have been using AE for many years, and have never ever ever been able to get good results from keylight, without a monumental amount of pissing about.
    Even though that footage is shot with a good camera and a very good lens, in a TV studio, the noise in the (original) pic is for me totally unnacceptable. I have done every keylight tutorial, read every discussion thread, tried every technique, and it still looks noisy and crappy.
    Heres the steps that I took with this piece of footage.
    bottom layer: crunched it with curves, used remove noise with minimal settings to smooth out the jacket a bit.
    Duplicate the layer. Apply keylight. set to screen matte. fiddle around a bit and get a good black/white matte. Use this layer as a Luma matte for the bottom layer.
    Duplicate bottom layer again, put it on top, and then mask around the problem area of his glasses arms.
    On top, an adjustment layer with channel mixer used as a spill suppressor, and with a “darken” blend mode.
    It doesnt matter wether I use this method (layer as luma matte), or with keylight set to intermediate results, or final results, or anything at all. All grey or darker areas have noise and grain. Lots of the edge as well.
    Its driving me crazy.
    mfg
    Simon
    You know I’m born to lose, and gambling is for fools, but that’s the way I like it, baby. I don’t want to live forever!
  • Tudor “ted” jelescu
    April 1, 2014 at 6:48 am
    For some reason I can’t connect o the link you provided to download the footage. However, there’s a trick that always works for me with Keylight- use the Intermediate Result, not the final. Add your own Spill Suppressor and you should be golden, no more noise.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Simon Roughan
    April 1, 2014 at 2:20 pm
    Hi Ted,
    thanks for taking the time.
    The server is down, therefore no more active link. And I have tried “Intermediate”, but as I wrote upstairs, nothing helps.
    I ended up doing the basic keying in premiere with Ultrakey, then through dynamic link tweaking in AE.
    I now have something that is acceptable. But I wish for once that it worked like it does in tutorials, where they click and its perfect.
    mfg
    Simon
  • Joey Trimmer
    April 1, 2014 at 10:13 pm
    I share your frustration with KeyLight. I always have a better initial result with Premiere’s UltraKey. I think Dave’s Alpha matte technique is worth a shot though. Otherwise, changing your workflow to key in Premiere and then bring the sequences into After Effects is another way to go. Good luck!
    “I’m your density. I mean, your destiny.” – George McFly
  • Simon Roughan
    April 2, 2014 at 7:37 am
    Oh Dave, if you had any experience of my technical colleagues, you would understand why I laughed out loud when I read that…
  • Todd Kopriva
    April 2, 2014 at 8:05 am
    Not that it helps you now, but that’s why we created the Key Cleaner effect:
    https://bit.ly/AE_CC_next_details
    After Effects team blog
