Activity Forums Maxon Cinema 4D Terrain Shader anyone ?
  • Terrain Shader anyone ?
    Posted by Rajarshi Basu on October 30, 2010 at 6:13 am
    I am using the terrain shader and getting some nice look, but when i put it on a poly object, the object doesn’t get totally covered…its like broken up.
    I have tried tagging Fit to Object, still it doesnt do a 100% wrap. Has anyone been successful in using the shader ? Also how can I combine it with some other material ?
    R
    Brian Jones replied 15 years, 9 months ago 2 Members · 3 Replies
  • Brian Jones
    October 30, 2010 at 7:34 pm
    the Terrain shader is a volume shader (or it needs a volume). If you put it on a cube it will give you a layer of terrain in between the bottom and top of the cube – the Height parameter determines how much. If it’s put on a poly plane it has no volume to fill and it starts to loose parts of itself after Height exceeds 50%
  • Rajarshi Basu
    November 10, 2010 at 6:03 am
    Hi Brian,
    I tried out the terrain shader, but its not wrapping around my poly objects. Is there any way to achieve this ? I am trying to get a landscape/ terrain look on my spheres.
    Raj
  • Brian Jones
    November 10, 2010 at 3:35 pm
    the terrain shader doesn’t do that. You will likely want to be using the Landscape object in Spherical mode or use sub-poly displacement in a material.
