Activity › Forums › Broadcasting › Terminated normalled patch panel question
  • Terminated normalled patch panel question
    Posted by Paul Thurston on August 19, 2015 at 3:30 pm
    Hello members of the pasture. What’s the advantage, if any, for Tri-level sync, HD SDI, and AES/EBU AES-ID3 (75 Ohms) signals when using a terminated normalled patch panel over a non-terminated normalled patch panel? I understand that normalled means the signal goes internally from top to bottom. I also understand that a terminated normalled means the bottom signal gets terminated when a patch is made. But for digital signals, I’m not sure if terminating the signal does anything for, say a digital HD video machine?
    Paul Thurston
    Producer
    Chile
    Paul Thurston replied 11 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
