Activity Forums Maxon Cinema 4D Tennis ball hair/fur
  • Adam Trachtenberg
    February 23, 2010 at 6:48 pm
    I don’t see your sample pic.
    The best way to do it, IMO, is with the Hair module. I’d use short, dense hair with a lot of frizz and kink. You could also use sub-polygon displacement, but it wouldn’t look as good.
  • Gareth Wrafter
    February 24, 2010 at 12:08 pm
    here is the ball I was referring to I used the hair mod but I did get lots of gaps in the hair showing the surface is there a way to fill these gaps with out the obvious adding more hairs?
  • Adam Trachtenberg
    February 25, 2010 at 6:09 am
    You can use a similar color on the underlying sphere to try and cover the gaps, but at the end of the day it’s just going to take a bunch of hairs to make it look right.
