Activity Forums Adobe After Effects Temporarily unparenting
  • Temporarily unparenting
    Posted by Bret Williams on March 5, 2010 at 4:22 pm
    Probably something i should know or have forgotten, but when you have a zillion layers parented to one layer, and then you decide you need to adjust the position, scale, etc. of that one layer, is there a way to temporarily “un-parent” or adjust the one layer without all the other layers adjusting?
    Also, related only to the word “parent”, we just had a baby girl and need a cool name for her! Preferably before we leave the hospital. 🙂
    Darby Edelen replied 16 years, 6 months ago 4 Members · 4 Replies
  • Joey Foreman
    March 5, 2010 at 4:31 pm
    Precompose the parent layer, leaving all attributes in the main comp.
    Lock your current window, double click your precomp layer, and make your adjustments.
    For a cool name, I like Zoë.
  • Roland R. kahlenberg
    March 5, 2010 at 6:08 pm
    Use the properties found in Effects>Disort>Transform to make the required changes to the parent layer without affecting its children.
    Congratulations to yourself and the wifey on the baby. If you’re an ardent AE fan, then Dave is the name you want to name the child – regardless if it’s a boy or a girl. 😉
    Cheers
    RoRK
    Sell your AEPs with broadcastGEMs’ DVD series of templates. Click here for more
  • Bret Williams
    March 6, 2010 at 5:08 am
    Thanks all! I was able to un-parent about 20 layers, and then make the change to the parent, a little x axis shift, and then reparent. I think as long as you don’t move the playhead you’re good, or maybe I had just patented them out of convenience. It was a large comp that had gotten out of hand.
    In the future though I think the precomposing would be the safest practice. I guess I wasn’t really thinking about precomposing after it’s already been patented, but should work fine. The layer is a parent, not a child.
    Thanks for the girl names! Andrea Zoe Williams. I’ll have to pass on Dave. 🙂
  • Darby Edelen
    March 11, 2010 at 7:33 pm
    I don’t have a full workflow to contribute, but I will mention that the “Select Children” command could be useful in this scenario 🙂 Right click the parent layer to do this.
    I should mention that it will select its childrens’ children as well.
    Congratulations on the new baby girl!
    Darby Edelen
