Activity Forums Adobe Illustrator Temporarily turn off effect? – Illustrator
  • Temporarily turn off effect? – Illustrator
    Posted by Naveen Mallikarjuna on November 11, 2005 at 3:12 pm
    Is there a way to turn temporarily turn off an effect in Adobe Illustrator CS2?
    I have a 3D effect on some text. However, I would like to be able to edit the text and change it’s color, without having to wait for the memory-intensive 3D effect to render every time I do this.
    I could not find anything in the Appearance palette. Is it possible to just disable this effect, and then turn it back on once I’ve settled on the color/words?
    Naveen
    Kotias replied 20 years, 9 months ago 3 Members · 2 Replies
  • Mike Gondek
    November 17, 2005 at 8:30 pm
    Would be great if appearance had visibility icons and the ability to change stroke weight there.
    There is no way to temporarily turn off the effect. The only adice I can offer is to in the 3D Effect turn off shading(everything shuodl go much faster), then turn it back on when done.
  • Kotias
    November 22, 2005 at 4:12 am
    Try temporarily turn off Make Preview/Outline Ctrl+O and write needed text in outline mode.
