Activity Forums Adobe After Effects Temporal keyframe issues
  • Temporal keyframe issues
    Posted by Tom Duncan on August 8, 2007 at 11:44 pm
    I’m having trouble getting temporal keyframes to do what I want. I have an Invigorator object that I want to slowly spin (y-axis) and ramp up until it is spinning wildly, then continue to spin at that rate until the comp completes.
    I made the first keyframe easy-out, but that starts off way too quickly too fast. So I made the second keyframe a bezier so I could adjust the velocity curve, which is no easy task. Finally got it where it may be acceptable and then added a third keyframe so it continues spinning, otherwise it would stop.
    Adding the third keyframes completely alters the second and now I am back to square one. I can’t seem to find a tutorial or even the AE help files to explain how keyframes in general work and so I am asking the Cow community.
    After using AE for over 7 years, I still don’t understand variable keyframing. Is there a source or explanation you can offer? Mooooo anyone?
    (Spacial keyframes dont seem to be nearly as difficult.)
    td
    Tom Duncan replied 19 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
