Activity Forums Apple Final Cut Pro Legacy Temporal jump with livetype
  • Temporal jump with livetype
    Posted by Robbie Allen on February 2, 2007 at 10:43 am
    This is more of a “why” than a “help!” – I’ve found a workaround, but any ideas as to the cause most welcome:
    Made a sequence in FCP – HDV (25fps). Built a title in Livetype – very simple fade in/fade out. Put title over sequence. All looked fine. Exported sequence using Quicktime conversion. Played back in QT – there’s a time-jump in the background video at the first frame of the title, maybe 2 frames. Same thing whatever output codec is used – H264, None, etc. Tried changing the field dominance in LT, upper, lower, none – no change.
    Changed the Quicktime Video setting in the sequence to ‘none’ – problem disappears. Most odd.
    Robbie Allen replied 19 years, 7 months ago 1 Member · 1 Reply
  • Robbie Allen
    February 5, 2007 at 12:28 pm
    Thanks Dave, you were bang on the money. I put in a compression marker at the first frame of the livetype, and problem solved! I love this place!
    Robbie
