Activity Forums Apple Final Cut Pro Legacy Templating out effects
  • Templating out effects
    Posted by Satesh Ramjattan on March 8, 2006 at 9:35 pm
    Hello,
    I am an Avid editor, and am starting to learn final cut at work. My question is to know if there is way to template out effects like you can in Avid. example is to build a motion effect that slightly pushes in on video and then save that move in a seperate bin or place for later use. I hope i explained right.
    thanks
    David Battistella replied 20 years, 6 months ago 2 Members · 1 Reply
  • David Battistella
    March 8, 2006 at 11:15 pm
    Select the shot with the effect move, etc.
    right click and select copy. ( or hold down option)
    select the shot you want the same effect on.
    right click and select PASTE ATTRIBUTES
    the move is placed on the new shot. The same goes for filters, motion and a bunch of other things as well.
    With specific effects (dissolves or transitions) you can double click on the effect and then grab the little hand tool in the top right corner of the viewer window, it changes to a hand, drag it to the browser and you have a custom effect that you can place in a bin.
    You can also drag these project to project. Try that on an avid.
    David
    Peace and Love 🙂
