Activity Forums Adobe After Effects Television Switched on effect in after effects.
  • Television Switched on effect in after effects.
    Posted by Antony86 on November 7, 2006 at 5:23 pm
    Hey, just wondering if anyone knows how to do this effect in after effects.
    A TV being turned on, so you get the white fuzzy effect, when it switches on, and you see ‘almost’ a wipe in i guess it is, white dot.(from the centre to out), and also the effect of a tv switching off.
    Ant
    James Lee replied 19 years, 10 months ago 4 Members · 3 Replies
  • Steve Roberts
    November 7, 2006 at 6:08 pm
    Search the COW, Luke. This has been discussed.
    TV. On. Static. That sort of thing.
  • Aharon Rabinowitz
    November 7, 2006 at 8:21 pm
    This is on my list for a video tutorial. Actually it’s TV off, but it would work the exact same way.
    Mostly, i’d
    precomp my video
    scale it down to 0 on the x and maybe 5% on the Y, and then animate if first scale up to 100 on the X, then 100 on the y
    Use the effects called tint to tint the entire thing white, then fade out the tint as it scales up
    use a lens flare perfectly centered for the flash
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
  • James Lee
    November 7, 2006 at 8:33 pm
    digital heaven has a cool plugin that does TV on, off, static for FCP…not sure if they have one for AE though but worth checking out.
