Activity › Forums › Adobe After Effects › Television static effect
Posted by Mmromo on March 7, 2006 at 12:06 amDoes anyone know how to create a TV static effect? The one that looks like your tv stations went off the air.
Thanks in advance!
Matthew Klahn replied 15 years, 4 months ago 5 Members · 4 Replies -
Aaron Zander
March 7, 2006 at 1:02 amwell, have you tried noise and grain and then i think noise, and then do it w/o color, another one would be here, a bunch of free plugins that are awsome
https://www.petewarden.com/ after effects plugins, free!!!! they have a static plugin with alot more versitility over the standard
Aaron Zander
Student edditor/visual creator
ims till learning, but don’t under estimate -
Justin Productions
March 7, 2006 at 1:21 amDepends wich version of Adobe After Effects you have.
Go in the effect menu: Noise > Noise.
Just play with the amount of noise.
If you don’t have that effect, that means you probably have a standard version of your Adobe After Effects.
Good luck!
Justin Productions
Tangerin01@hotmail.com
Adobe After Effects 6.0 Professional -
Paul Hamrick
March 7, 2006 at 8:36 amhttps://www.petewarden.com/PluginHelp.htm#Static
Static – Produces an output of random noise, like the static on a TV screen getting no signal.
Parameters
1. Greyscale With this turned on, all the colours in the image will be shades of grey, rather than all hues, giving a more TV like appearance.
2. Two Tone With this enabled, there will be only two colours used for the static, giving a more noisy, contrasty look.
Matthew Klahn
April 10, 2011 at 8:13 pmyou can go on youtube and type in something, then download it, or you may want to check out video copilot’s video streams hd.
