Television Playback Warping / Waving / Rolling on Left Edge
I have searched and searched for a solution to my problem with no luck yet so here goes my first post. Not sure if it should be in this thread or not.
Project:
DVD for viewing mainly on common PAL telvision sets along with compatibility for pc playback and other tv sets.
Problem:
Description:
I have made a short animation (logo flying over a static landscape background) and only when played back on the television set does it distort slightly on the left edge of the screen always. The effect can best be described as edge wobbles or imagine a flat ground surface with a ball rolling underneath it. This occurs as the logo flashes bright in one section and then again shortly later as the logo zooms in and turns. The rest of the time its flying over the landscape background all is well.
I have searched and tried everything i can think of from colour changes and fields and render settings etc etc etc but nothing makes any difference. For example i have rendered all forms of video from 3d app including individual frame images and composited all in premiere pro with the same end results.
I thought it might just be my television but have tried a test dvd on another set and the same occured. Note that commercial dvds and similar introduction logo animations play back just fine on my tv unlike my own creation. Also note that just one other dvd i watched the other day had a similar intro logo effect but the movie was fine. Finally i have noticed one station on my set playing an old movie today which was a bit smaller than the screen (having black edges all around it) and the black edges were wavy (vertically) on both sides of the picture similar to my problem.
The closest I have coem to any help or similar problem reference always mentions colours to be a possible cause but I have tried washing it all out to a really ugly demo but safe and still it occurs (although can be minimised slightly or perhaps just less visible to the eye).
In summary I really need to stop the background from warping as the logo passes over it due to the background being an arial image of rela land which looks unreal in the sections and stages where the land rises (the rolling ball underneath effect).
Does anyone know what is causing such problems and can help?
