Activity › Forums › Apple Final Cut Pro Legacy › Television hook up with iMac G5
  • Television hook up with iMac G5
    Posted by Ryan Schoonmaker on January 9, 2007 at 5:17 am
    I have an iMac G5 and am editing in Final Cut Pro and need to hook up a televion for color correction and final output. The G5 I have has only firewire and usb 2 ports, any way i can do this for pretty cheap or do i need some new hardware?
    Debe replied 19 years, 8 months ago 2 Members · 1 Reply
  • Debe
    January 9, 2007 at 6:33 pm
    You need something that will turn the data coming out the FW connection into something a monitor can recognize, or you need an internal card…wait, you said iMac. No cards. Never mind.
    You need a deck or a camcorder or a DV bridge of some sort.
    There is a pretty good diagram showing proper system setup in the manual.
    debe
