Activity Forums VEGAS Pro Teething problems with Vegas 13
  • Teething problems with Vegas 13
    Posted by David Pendry on November 18, 2014 at 9:40 am
    Good morning.
    I’ve been using Vegas for quite a few years (versions 6, 8, 11 and, as of today, 13), and I’m struggling with a few things on a project I have just ‘finished’ on Vegas 11.
    Importing it was fine – it came in no problem.
    (The increased resolution is fantastic, by the way!)
    I have ‘accidentally’ moved the ‘Video Fx’, ‘Explorer’ and ‘Transitions’ ‘windows (oops) – and now I can’t get them back into their original positions, plus, I appear to have deleted the ‘Video FX’ window!?
    How do I get these back?
    Also, it appears to ignore any FX that I add to a clip!? I’ve done all the usual checks, but it’s still ‘ignoring’ everything.
    The new layout is a little cluttered (even with two monitors) compared to 11, but I’m sure I’ll get used to it.
    I am in a real hurry to get this project re-rendered at a decent resolution, so a prompt answer would be really appreciated.
    Many thanks.
    David.
    Ah-haaaaaa! Done it! 😉
    (new computer as well, you see?)
    John Rofrano replied 11 years, 9 months ago 2 Members · 1 Reply
  • John Rofrano
    November 18, 2014 at 11:18 am
    [David Pendry] “I have ‘accidentally’ moved the ‘Video Fx’, ‘Explorer’ and ‘Transitions’ ‘windows (oops) – and now I can’t get them back into their original positions”
    I would start by resetting your windows back to the default: View | Windows Layouts | Default Layout. It’s also important to note that the docking behavior has changed with Vegas Pro 13. You must hold the Ctrl key down as you drag a window to dock it or else it will never go back into the docked position.
    [David Pendry] “plus, I appear to have deleted the ‘Video FX’ window!? How do I get these back?”
    Try: View | Windows | Video FX (Alt+8)
    [David Pendry] “Also, it appears to ignore any FX that I add to a clip!? I’ve done all the usual checks, but it’s still ‘ignoring’ everything.”
    Make sure that you don’t have the FX Bypassed in the Preview:
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
