Activity Forums Apple Final Cut Pro Legacy Technique for grading flashback
  • Technique for grading flashback
    Posted by Simon Roberts on September 22, 2008 at 9:30 pm
    Hi there,
    I’m cutting a promo from rushes shot in a studio of characters in a drama. i am looking to create a flashback sequence from drama material from the last series. I am looking for an effect to take me from the rushes to the prog material and would like a suggestion on how to grade to make it look like a flashback.
    I’ve used flashes and various through white dissolves before + I’ve used the usual vignette crush blacks film effect, does any one have any other ideas
    Efrain Schunior replied 13 years, 11 months ago 4 Members · 4 Replies
  • Peter Wiggins
    September 22, 2008 at 10:14 pm
    A bit of glow, dial out some colour, run it at a lower framerate, bit of reverb on the audio….
    Peter
  • Simon Roberts
    September 23, 2008 at 7:02 am
    cheers thanks
  • Rebecca Lally
    September 23, 2008 at 6:34 pm
    Using a little bit of film clutter for transitions (overlaying some end burns and light leak style film flashes) can be a nice transitional element, especially if you’re working with the vignette. But if it doesn’t work to suggest an old movie kind of feeling, I think a little bit of diffusion, or as was already mentioned, a glow – works nicely. Don’t know what plugins you have, but Too Much Too Soon is a set of sharware plugins that has 2 great diffusion filters.
    https://www.mattias.nu/plugins/
    Also, if you want to emulate a lab process, like bleach bypass, you can use the 55mm digital film tools plugins. I think it’s now called DFX 2 and distributed by tiffen. You can download a trail at the website: https://www.tiffen.com/dfx_v2_home.html
    That particular set of plugins has some really nice pro mist filters and other tools that can help you soften the look. But you don’t necessarily have to go soft or slow with flashbacks. Look at all the “Saw” movies. Their flashbacks are generally sped up and extremely harsh looking. But then again, that might not be useful if you’re not working on a horror movie promo. 🙂
    “Without lamps, there’d be no light.”
  • Efrain Schunior
    October 19, 2012 at 5:27 am
    great tips everyone! for our telenovela i also like to use a bit of old 8mm stock overlay to give it an old feeling.
