Activity › Forums › Canon DSLR Cameras › Technicolor LUT
  • Daniel Hughes
    May 14, 2011 at 5:46 pm
    It’s delicious! Very fantastic.
    It’s good for shooting dark things, like dark coloured dogs or extremely dark skinned people and as it preserves so much detail in all of the regions.
    The fidelity is a dream!
    Daniel Hughes
    Amateur Writer, Director,
    Director of Photography
    United Kingdom
  • Ronald Jensen
    May 15, 2011 at 2:57 pm
    I tried it on my canon EOS 550d (T2i).
    It is very good looking. Quite a lot more detail in the shadowz.
    But.. On my macbook with 4GB Ram and Finalcut 7 it takes ages to render the LUT profile.. So I am considering if it is worth using without LUT and just fixing colors and levels in Final Cut’s built in color control..?
    Anyone having an opinion on that?
    Ronald
  • Jeremy Garchow
    May 15, 2011 at 9:24 pm
    How are you rendering the LUT?
  • Ronald Jensen
    May 15, 2011 at 9:27 pm
    I am rendering in Final Cut through the Magic Bullet plugin. I put the effect on each clip and then render from timeline.. Is there a better way?
  • Jeremy Garchow
    May 15, 2011 at 9:39 pm
    I was planning to go through color, or perhaps use the Kona card to kiPro.
    Somewhere, you’re going to have to apply the LUT.
    You could use whatever you want. You also don’t have to use it if you don’t want to.
  • Ronald Jensen
    May 15, 2011 at 9:45 pm
    Yeah, I guess it does not really make sense to just use it as a ‘flat’ image for ordinary color-grading without applying the LUT..? But I am only a novice in this area…
  • Jeremy Garchow
    May 15, 2011 at 10:44 pm
    It’s just a suggested LUT. You can grade it however you’d like.
    You can choose to use their LUT, and then further grade with that, or just start from scratch.
