Activity Forums Adobe Photoshop Technical Question using photoshop
  • Technical Question using photoshop
    Posted by Espnetboy3 on March 10, 2006 at 12:36 am
    Does anyone know what this means, its a message I got when combining a picture into a new file I made. “The target document has a different depth than the source document. This may result in lower than expected quality. Are you sure you wanted to proceed.?
    Another question I have was while doing work in photoshop for video (DV) should I work from NTSC DV1 720×480 from the start with a certain pixel or color profile set? I ask this because I enjooy doing matte paintings and backdrops. Im sure sometimes I would have to make the document bigger if there is a pan or something involved.
    Help would be great. Thanks
    Espnetboy3 replied 20 years, 6 months ago 2 Members · 2 Replies
  • Richard Harrington
    March 10, 2006 at 1:00 am
    Q1 You are adding a 16 bit iamge to an 8 bit canvas
    Q2 Personal choice… start bigger if you are going to move background
    Richard M. Harrington, PMP
    Author: Photoshop CS for Nonlinear Editors
    Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
    Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
    edit – produce – direct –
  • Espnetboy3
    March 10, 2006 at 4:23 am
    Yes my photoshop has been switching this up on me lately. The pic I wwanted to pull into my blank document was shot with a digital camera so i suppose it was 16 bit. Thanks
