Activity Forums Adobe After Effects Expressions Technical question…
  • Technical question…
    Posted by Stephen Reber on June 25, 2009 at 4:28 am
    Hey guys…
    I have a little bit of a technical question. I am looking at the wiggle() and random() expressions. They both generate random values although both have different effects, but why is it that the random() expression can be +/-/* and / to/from a value, but the wiggle() expression has to be PART of a value… transform.position.wiggle()[0]??
    I am just trying to better understand the inner workings of expressions.
    Thanks in advance for your help…
    Stephen =]
    Stephen Reber replied 17 years, 2 months ago 2 Members · 2 Replies
  • Dan Ebberts
    June 25, 2009 at 1:15 pm
    That’s just the way they implemented it. random() is a stand-alone random number generator and wiggle() is property method used to apply perlin noise variations to the specified property. You can separate wiggle() from the property value like this:
    w = wiggle(1,50) – value;
    Or, if you’re wiggling the property other than where the expression lives:
    w = transform.position.wiggle(1,50) – transfrom.position
    Dan
  • Stephen Reber
    June 26, 2009 at 2:41 am
    Excellent!
    Thanks Dan =]
