Activity Forums Adobe Illustrator technical drawing grid effect
  • technical drawing grid effect
    Posted by Lucy Orgill on February 7, 2011 at 7:17 pm
    Hi There,
    I originally posted this under the Indesign Forum but I think the Illustrator one is probably more relevent!
    I need to make an illustration similar to the one attached
    which was taken from a photographthe one I want to do is a photo of a train
    I can trace around a photo without problems in illustrator but I was wondering if there is a way to get the ‘grid’ lines could this be done in illustrator easily or another program first and then the lines traced? if I need to get another software programme please could you advise?
    Any advice would be great.
    Thank you
    Lucy
    Lucy Orgill replied 15 years, 7 months ago 2 Members · 2 Replies
  • Les Nemeth
    February 11, 2011 at 1:10 am
    That’s called a 3d wire frame, and you create it with a 3D program. There are free ones (Blender), moderately priced (Silo ~100 bucks) or more expensive ones. Google is your friend!
    But if you’ve never used a 3D program, get ready for some learning curve!
  • Lucy Orgill
    February 13, 2011 at 2:10 pm
    Hi Les,
    Thank you for the advice, I will look into these!
