technical comp settings for a composite project for web
Hi Guys,
Looking for opinions on workflow settings for a composite job delivered as full res (prores) files that will be intergrated into a web site. Here are the details:
– Green screen footage shot on XDCAM EX 1080 25P
– BG plate recieved as 1024×576 PNGSo i have begun by keying the HD footage in the matching comp. Then I will move the keyed footage comp over to an SD comp and composite this into the plate scene. just not sure which SD comp settings I should use here.
I tried setting a SD widescreen Square Pixel comp but the frame size of this is 1050 which is larger than my plate in width. Also looked a SD Widescreen setting and I get the same problem. The plate does not have the same width. It’s not a super issue th fit the plate to the comp with but would like to do it the right way to start.
I’m thinking that because I’m delivering the composite to a web programmer that I should work in Square pixels and deliver square pixels on output as they will not be working in anamorpic when it comes to integrating the footage into Flash. and this would keep everything 16:9 and web pixel aspect.
So 1. Should I stretch the plate out to 1050pix?
2. Should i compoite in the square pix comp?
3. should I render the final scenes as 1024 or 1050 wide?
4. How does this all work with Pro res when it’s a custom frame size?
look forward to hearing your thoughts
