Activity Forums Apple Final Cut Pro Tech Transitions
  • Tech Transitions
    Posted by Gerry Fraiberg on January 11, 2012 at 2:45 am
    Industrial Revolution has just released a very tasty package of transitions.
    https://www.idustrialrevolution.com/x1-tech-transitions
    XEffects Tech Transitions are 28 dynamic hi-tech effects for Final Cut Pro X that will add impact to any project.
    Corporate productions to rap videos, broadcast sports programmes to personal web edits can all get a stylish hi-tech look with these fresh new sophisticated transitions. Stylish and easy to use, these transitions have been built by editors for editors and take the hard work out of making that video sizzle.
    Transitions that would have taken many layers, complex mattes and some maths to complete are now possible within FCPX with a couple of clicks.
    Tech Transitions is the first commercial product for FCPX to feature temporal or retiming of video within the effect. Use the automatic repeaters to step or duplicate action on the cut.
    The freeze versions of effects holds the last frame of the outgoing media and the first frame of the incoming media, performing the transition between the two stills. Perfect for emphasising movement and because they are transitions, the freezes will automatically update when the effect is slipped, duration changed or copy and pasted. No more razor blading and making freeze frames!
    $49 buys you 28 effects in the pack or you can test out the transitions on your projects by downloading the watermarked trial for free.
    Gerry Fraiberg replied 14 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
